Need help
Old Dec 3, 2003 | 03:39 PM
xdef00's Avatar
xdef00
I ♥ Acer
Default Need help
<IMG style="WIDTH: 33px; HEIGHT: 36px" height=46 src=smileys/smiley19.gif width=44 border="0"><FONT size=6> I havea 99 mustang. I need help installing a new cd player in my dual deck (cd player and tape/radio) i dont know how to do it. Please e-mail me with instructions!! PLZ!!</FONT>
Old Dec 3, 2003 | 07:25 PM
whitelightning's Avatar
whitelightning
Default Need help
You need to pull the decks out, I assume you have two separate decks. Then I would recommend getting a wire harness this will plug into your existing plugs that you pull off of your current radio. One will probably be power and the other will go to the speakers. The other end of the wire harness will be color coded to the after market radio wires, No cutting required and if you ever de-install to sell you can put the factory radio back in with minimal trouble!!! Hope this helps. Also the factory radios have two holes on the left and right side that allow for a special ford puller to pull the radios out, I've used nails to do this same thing but I would recommend buying the pullers, they are cheap and your local auto parts store should carry them, good luck!!
