Engine Block Casting Number
Old Mar 12, 2011 | 10:34 PM
gary taylor's Avatar
gary taylor
Question Engine Block Casting Number
I am a new member and im trying to figure out what i have,the block number is D5AE-6015-E can anybody help me out?
Old Mar 13, 2011 | 09:20 AM
hminus's Avatar
hminus
Hey dude.. this is lewis... check you casting numbers again. I think you may have a C5AE-6015-E (not a D)... The C5AE will come back to your 289 HIPO.. Specs are available with a quick google search. I also have PDF somewhere with the ford casting codes and specs, but need to find it.. Have you found your motorcraft - autolite carb yet? I would fork over the $500 bucks for a pony carb... It was the best thing I ever did for the mustang...
Old Mar 14, 2011 | 08:54 PM
gary taylor
Hey Lewis, i should have known that u were part of this club. you are right the casting number was dirty and it was a c and not a d. i ordered a rebuilt from advance 178.00 and runs nice. i dont want to put much money into it since its in the 79 f-150. i do have a nice original motorcraft on my 66 stang. maybe someone can answer this, if the 289 hi-po block is any different than the 289 block?
Old Mar 15, 2011 | 09:15 AM
65stangnut's Avatar
65stangnut
Lewis, the Hi Po block and the regular block are the same block, the difference is if they are still there on your Hi Po block are the main bearing caps. The Hi Po block had larger main bearing caps to handle more horse power. Some times the serial number of the car it was from was stamped on the Hi Po block but not always. The casting numbers were different so you knew which ones had the larger main bearing caps.
Old Mar 16, 2011 | 08:35 AM
hminus's Avatar
hminus
good to know...
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Gary Ugarek
Aug 26, 2015 08:41 AM
