AC Pulley Question!!
Old May 2, 2011 | 06:55 PM
Nacho93's Avatar
Nacho93
Exclamation AC Pulley Question!!
Okay so I am new to the Mustang world and just have a quick question.
When I turn on the AC the Pulley stops spinning for a couple seconds then goes back rotating for about 10 sec. It does this on and off and will make a hiss sounds when it stops spinning. Is this bad for the belt or is it supposed to do this?
Old May 7, 2011 | 05:20 AM
wizwrath's Avatar
wizwrath
the off and on cycling is normal, if you put the A/C on high, and it still keeps rapidly cycling, you may be low on freon, the hissing sound might be (with out hearing it), when the clutch releases the plates slip a little and it might be making that metal slip sound, or the bearing might be going bad.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
