car bogs down under heavy acceleration help
Old Jun 19, 2011 | 03:56 AM
torchred02's Avatar
torchred02
Default car bogs down under heavy acceleration help
while driving home i floor the gas pedal to the floor. car accelerates like normal but suddenly car bogs down... almost like it missed a gear or something... i let off the gas and the car seemed to accelerate normal again.
i stop and take off again and floor it and as the rpms climb the car just bogs down again.. i have to let off the gas so it drives normal again. it makes this noise as it bogs down. check engine light came on as this happened.
code was for a cam position sensor. replaced the sensor and weeks later car is still bogging down under heavy acceleration and check engine light came on again for same thing.
changing the sensor didn't do anything. Ive just been driving normal.
car shifts/acts fine when driving normal.
what could be wrong with my car?
Old Jun 21, 2011 | 02:46 AM
petrock's Avatar
petrock
What is the exact code you are getting. Most codes have multiple causes, and sometimes they aren't that obvious. Could be a bad coil or spark plug wires etc etc. The list goes on...
Old Jun 29, 2011 | 11:49 AM
machracer11's Avatar
machracer11
is the car an auto or manual?
Old Jul 1, 2011 | 04:05 PM
mhefner5's Avatar
mhefner5
i would inspect the change the spark pugs and wires and put some injector cleaner in and change the fuel filter
Old Jul 1, 2011 | 04:06 PM
mhefner5's Avatar
mhefner5
i would change the spark pugs and wires and put some injector cleaner in and change the fuel filter****
Old Jul 1, 2011 | 04:21 PM
DJ19895.0's Avatar
DJ19895.0
Bogging under load sounds like a spark or fuel issue. Check the fuel filter, plugs, and wires. Replace them all if they have not been replaced before.
Old Jul 8, 2011 | 05:51 PM
torchred02's Avatar
torchred02
thanks guys. i was thinking it was a dead spot in the tps
ill replace plugs and wires, fuel filter and tps
Old Jul 8, 2011 | 05:52 PM
torchred02's Avatar
torchred02
its auto by the way
Old Jul 8, 2011 | 05:57 PM
Derf00's Avatar
Derf00
Gentleman's Relish
are you redlining?
Old Jul 10, 2011 | 09:34 AM
LS1fivepointO's Avatar
LS1fivepointO
If you're running cats, you may also want to check that they aren't just at their life's end now. But Plugs, wires and fuel filter first!
