Spark plug question
Old Sep 2, 2005 | 10:28 PM
Crzybiker's Avatar
Crzybiker
Default Spark plug question
Can someone explain to me the deal of spark plugs and their heat ranges?
Old Sep 3, 2005 | 12:26 AM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: Spark plug question
Engines convert heat to mechanical power. Stock engine will have a compressions ratio (CR) and plugs with a heat range. Heat range is chosed so that plug remains at a specific temperature, so that deposits are burned on the plug, and so that it does not serve as a hottest source in the cumbustion chamber. When you increase CR, either by altering compression ratio, advancing timing, or increasing boost, more heat is converted to power and less heat escapes. If we increase CR and leave heat range the same, plug will retain more heat and be a source of heat in the combustion chamber, causing preignition. A plug with lesser heat range will retain less heat, and thus prevent preignition.
If heat range is choose too low for a given CR, plug will be build up deposits, spark will have hard time firing.
Old Sep 3, 2005 | 01:53 AM
kartracer55's Avatar
kartracer55
This should give ya a good understanding...
http://www.densoiridium.com/heatranges.htm
Jim
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Emblazoned
Sep 3, 2015 10:45 PM
cbird1177711
Sep 2, 2015 04:12 PM
