Spitting and Sputtering
Old Sep 4, 2005 | 03:50 PM
robotdoc's Avatar
robotdoc
Default Spitting and Sputtering
I have a stock '98 GT. It ran great except that it give a little spark knock on quick acceration. I just put new plugs in and now it runs rough and spits and sputters especially on quick acceleration. I put Autolite plugs in it which the dude at the parts store recommended. I saw on the emmisions control sticker the the plug gap is .052 - .056 so I set them all at .054. Obviuosly this is something to do with the plugs. The engine has the electronic ignition (no cap and rotor) system and thus the timing can not be changed. I have been over the engine to be sure everything is tight and connected properly. I can 't think of anything else to do. I would greatly appreciate any aand all suggestions!
Thanks
Old Sep 4, 2005 | 03:59 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: Spitting and Sputtering
Remove plugs and set gap to 0.052 inch gap. (that is INCH).
Condition you descibed suggest that you did not connect proper wires to proper cylinders. So do that also, after you set the gap to 0.052 inch.
The type of guage you use also plays a role. It should be a swiss army knife type, with blades popping out. The guage should go between the plug very very tight.
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
JaxJags88GT
Mar 11, 2005 10:43 PM
97STANG
Jul 2, 2004 07:18 PM
