Sponsored by:
Sponsored by: DashLynx
think I gotta blown headgasket
Old 08-21-2011, 03:40 PM
zinsavage123
zinsavage123's Avatar
Default think I gotta blown headgasket
I have done had my coolant flushed and changed yet my coolant looks like it has oil in it it dont smell like it though so I dont know what to think? also my oil is not milkyish and it doesnt overheat and the exhaust doesnt smell sweet? any ideas guys?
zinsavage123 is offline
Old 08-21-2011, 05:57 PM
Mixednuts
Mixednuts's Avatar
Ok - I'm confused ----- What are you trying to say ?????????
Mixednuts is offline
Old 08-21-2011, 11:18 PM
zinsavage123
you serious lmfao im hinting I wanna know if this looks like a blown headgasket from my coolant pics?
Old 08-22-2011, 03:27 AM
petrock
petrock's Avatar
If all the old coolant wasn't removed when you had it flushed, it could be old coolant mixed with the new coolant.
petrock is offline
Old 08-22-2011, 02:25 PM
Mixednuts
Mixednuts's Avatar
Pics did not come up last time I looked. I see them now. That does not look like oil to me.
Is your car blowing white smoke out the exhaust pipe? If so it's your gasket.
Do you need to keep adding coolant? If so it's your gasket.
I always thought if the gasket was gone coolant would be in your oil - not oil in your coolant.
Old 08-22-2011, 02:26 PM
Mixednuts
Mixednuts's Avatar
It's almost looks like some type of radiator sealer is mixed in. Like stop leak or something?
Old 08-22-2011, 09:10 PM
zinsavage123
I do have some white smoke/exhaust fumes cause I have a o/rx pipe so I cant tell on the white smoke thing?
Old 08-26-2011, 06:45 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Speaking as someone how has had a HG go while driving 70MPH on the freeway you WILL know when you loose it. If the car is still running then you didnt loose the gasket.
Matthew
Matt's 95 Stang is offline
Old 08-28-2011, 11:49 PM
petrock
petrock's Avatar
Your motor will run with a blown head gasket, it will just run poorly. Sometimes the only noticeable indication is losing coolant or oil or both. If you severely blow your head gasket(s) then thats a different story...
petrock is offline
Old 08-28-2011, 11:55 PM
zinsavage123
well I still had to add a lil coolant yet im not smoking, it isnt running poorly and their is no coolant in oil or vice versa wtf could it be??? im using prestone 50/50 distilled coolant if that matters??
Quick Reply: think I gotta blown headgasket
