For those guys with Camaros
Old Sep 8, 2005 | 08:42 PM
35annivGT's Avatar
35annivGT
Default For those guys with Camaros
My friend just got this Camaro and i was wondering what HP he has and how much there is to the wheels. Trying to give him an estimate before he takes it to the dyno. Here is the info....
1993 Camaro z28, LT1 - 35,000 miles
COMP CAMS CUSTOM CAM
AIR FLOW RESEARCH HEADS 68CC
MORRISSON BEARINGS 1.5MM 2MM
2.02 1.60 STAINLESS STEEL VALVES
11.0:1 COMPRESSION GASKETS
COMP CAMS 1.6 ROLLER ROCKERS
MOTORSPORT 24LB INJECTORS
BBK 58MM THROTTLE BODY
SLP DUAL COLDAIR PACKAGE W/K&N FILTERS
SLP 1.75 INCH HEADERS
MSD 6AL IGNITION WITH TIMING SENSOR
MARCH UNDERDRIVE PULLEYS
4.10 RICHMOND GEARS (brand new)
ACCEL 8.8MM WIRES THERMO-COATED 9000 EXTREME
DYNOMAX EXHAUST 2.5 INCH WITH CHROME TAILPIPES
FUEL PRESSURE REGULATOR
Z INDUSTRIES CUSTOM CHIP
GRANATELLI TOWER BRACE AND SUBFRAME CONNECTOR
MSD RPM ACTIVATED SWITCH
Spec Stage 2+ Clutch (brand new)
EIBACH DRAG SPRINGS
FELFRO UPPER AND LOWER GASKETS
3 WIRE O2 ADAPTER HARNESS AND SENSOR
TAYLOR IGNITION WIRE SHIELD KIT
AUTOMETER GUAGES
SPEEDLINE 17 BY 9.5 WHEELS
DUNLOP 275/40/17 D40 M2 TIRES
Old Sep 9, 2005 | 12:13 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: For those guys with Camaros
It's tough to say without knowing the cam specs but my guess is around 330-340 rwhp. Remember though that the type of dyno and the dyno operator can make a huge differance in the numbers he sees. Let me know what it puts up when he does take to a dyno.
Old Sep 9, 2005 | 12:53 AM
35annivGT's Avatar
35annivGT
yeah these are the Cam specs
width 534/544 duration 210/220
Old Sep 9, 2005 | 02:05 AM
93StangLX's Avatar
93StangLX
FAST DONT RACE HIM YOU WILL GET OWNED
Old Sep 9, 2005 | 11:55 AM
JD1969's Avatar
JD1969
ORIGINAL: 35annivGT
thats a pretty small cam, I bet he only sees about 315 rwhp
Old Sep 9, 2005 | 04:34 PM
ZW99GT's Avatar
ZW99GT
thats quite a mod list for a 350 to get only 315rwhp. I thought camaro's woke up to mods easily. JD, doesnt your car have less than that, with more hp? I dont understang
Old Sep 9, 2005 | 04:39 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
jd has a different motor. same size, but different
Old Sep 9, 2005 | 05:16 PM
JD1969's Avatar
JD1969
ORIGINAL: ZW99GT
You know what I missed the AFR heads, I bet he see more hp than I thought. But yes as Redass said I have a totally different motor LS1 (me) vs LT1, there is a huge difference in the heads and how many cfm's they flow. I put down 352 rwhp before my cam swap, I would think that he will be near that.
Old Sep 9, 2005 | 05:43 PM
99saleen351r's Avatar
99saleen351r
ORIGINAL: 35annivGT
EIBACH DRAG SPRINGS
AUTOMETER GUAGES
Those mods i highlighted are good for 200rwh alone
Old Sep 9, 2005 | 09:54 PM
35annivGT's Avatar
35annivGT
you mean 300??
