problems.....
Old Sep 9, 2005 | 08:44 PM
89fiddy's Avatar
89fiddy
Default problems.....
recently when i start my car up, after it has been sitting over night, my a/c or blinkers will not work. after about 5-10 min. of driving all of my emergency lights ( low gas,low coolant,oil,windshield washer fluid) flash on and then my a/c and blinkers start working. Any clue on why this happens? Another thing is my low coolant light is always on. I check my coolant and see if its low and it always looks fine. I add some just in case and my coolant light is still on. can it be a bad fuse? I bought a new sensor and resevior about 4 months ago so that should not be a problem,i hope. I need feedback.
thanks
Old Sep 9, 2005 | 11:43 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: problems.....
Bad ground???? [:-]
1) Let's do this, disconnect the battery cable.
2) Remove computer, clean teeth on computer and harness side with rubbing alcohol.
3) Clean the battery terminals
4) Connect the battery cable back.
If it still doing this, you may have a bad ground somewhere.
Old Sep 10, 2005 | 05:11 AM
99saleen351r's Avatar
99saleen351r
Oh god^^^^^^^^^^^^^^^^^^^Dude you dont even know if its a fuel injected car or anything!! the coolant level problem is most likely a bad senser if the fuse was blown it wouldnt light up.
Old Sep 10, 2005 | 07:26 AM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
will you guys stop throwing tools at each other?
sheesh
Old Sep 10, 2005 | 11:16 AM
4600cc's Avatar
4600cc
I ♥ Acer
ORIGINAL: 99saleen351r
the coolant level problem is most likely a bad senser[] if the fuse was blown it wouldnt light up.
Author does not have a coolant level problem. He said whenever he checks the level it's fine. What he is having is ECM related, since ECM controls the guage cluster. 89fiddy, follow those trouble shooting steps, hopefully it's just some water on ECM harness. Should it be a bad ground it will be very hard to find.
Old Sep 10, 2005 | 01:37 PM
99saleen351r
He said the light stays on and i said most likely its the sensor meaning if its full and the lights on its the sensor...Hard to understand??
Old Sep 10, 2005 | 01:50 PM
4600cc's Avatar
4600cc
I ♥ Acer
No, all of his warning lights flash after about 5-10 min of driving. It is highly unlikely all of the sensors went bad all of a sudded and all at once. Apperently this is hard to understand for you.
Old Sep 10, 2005 | 08:11 PM
99saleen351r
He had two different problems that he asked about and I was answering the second one??Understand??
Old Sep 10, 2005 | 08:59 PM
4600cc's Avatar
4600cc
I ♥ Acer
No he has one problem, not two. He's warning lights will flash after driving it for a while, ask him.
Old Sep 10, 2005 | 09:02 PM
4600cc's Avatar
4600cc
I ♥ Acer
A difficulty of reading and understanding is expected from someone who thinks there is cap, rotor, and plug wires on 2002 GT.
