4 barrel...etc???
Old Sep 12, 2005 | 10:34 PM
Dan9687's Avatar
Dan9687
Default 4 barrel...etc???
when someone says 4 barrel etc. what does this mean??? Im pretty sure it has something to do with the carb but not sure what?
Old Sep 12, 2005 | 11:03 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: 4 barrel...etc???
A four barrel has four venturies or barrels as they are called somtimes. Look down the throat of a carb and you see what I mean.
Old Sep 13, 2005 | 01:58 AM
Dan9687's Avatar
Dan9687
Is there a benefit of having 4 over lets say 2???....If I had to guess I would say more air flow but not sure??? And this 4 barrel stuff only apply's to carburateted cars obviously right?
Old Sep 13, 2005 | 02:58 AM
JD1969's Avatar
JD1969
ORIGINAL: Dan9687
Correct more air flow, carbs come in sizes measured in CFM (cubic feet per minute) the carb needs to be matche dto the engine size, go too big and you lose power.
Old Sep 13, 2005 | 11:33 AM
closer9's Avatar
closer9
ORIGINAL: Dan9687
and TBI (throttle body injection) which is pretty much a carburetor with a fuel injector in each "barrel".
Old Sep 15, 2005 | 01:43 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
also 4 barrels is not always faster...i had a 82 stang with a 2 barrell on it...i swaped it out for a 4 barrel( stock intake) and the car slowed down 7tenths . so i made a bet to my cousin that it was a problem some where else and not the carb -intake...so i put the old carb intake back on and it picked that e.t back up...i guess the motor was using as much air -fuel it need and the 4 barrel just added more than it used causing it to slow down
Old Sep 15, 2005 | 02:26 AM
JD1969's Avatar
JD1969
ORIGINAL: 5.0mustang5speed
Did you use an adapter to fit the 4 barrel carb on the 2 barrel intake? Because that will choak your air flow badly. Also what size 4 barrel was it and was it tuned right, if done correctly it should have made more power but not much if the engine was all stock.
Old Sep 15, 2005 | 04:39 PM
5.0mustang5speed
I ♥ Acer
we used a factory alum ford 4 barrell intake..and a 600 holley...the motor was stone cold bone a## stock...it was awafull
Old Sep 15, 2005 | 11:41 PM
vfast's Avatar
vfast
I ♥ Acer
it you would have used a holley 450 with the air hone milled and some tuning it would have picked up a few .10ths
