347 STROKER QUESTIONS?
Old Feb 7, 2012 | 09:36 PM
BIKERBOY1000's Avatar
BIKERBOY1000
Default 347 STROKER QUESTIONS?
I am wanting to build the 347, was told my a friend of mine i would have to convert the cam over to a roller cam, do i really have to do that. i will not be racing, just cruising around, want the speed, but not going to. not planning on using the stock heads, proably going to get some good aluminum heads. just dont care to convert it over to roller cam. any suggestions would be nice. thanks the car is a 66 mustang, i pulled a bad 6 cycl. out of it.
Old Feb 8, 2012 | 06:44 AM
wizwrath's Avatar
wizwrath
No, you dont need to do a roller cam conversion to do a 347. But keep in mind, since you are going to be in there why not do it? Its fairly easy and you dont have to worry about cam break in procedures, etc. And the technology with rollers especially for the street is a lot better then standard lifters.
Old Feb 8, 2012 | 06:36 PM
BIKERBOY1000
WHAT IS THAT GONA COST ME? I PRICED THE SET-UP,, ITS A LITTLE STEEP... IF I WAS RACING IT I WOULD DO IT.. MAY DO IT LATER... IM IN THE HVAC INE OF WORK.. WE ARE TERRIBLY SLOW RIGHT NOW.. SO IM NOT LETTING LOOSE OF TOO MUCH MONEY AT THE MOMENT!! THANKS FOR THE REPLY..
Old Feb 9, 2012 | 04:58 AM
wizwrath's Avatar
wizwrath
Not a problem, take your time and do things right and dont lose your patience with your stang!!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
