oil pressure........
Old Sep 16, 2005 | 08:33 PM
HATCHEDIN87's Avatar
HATCHEDIN87
Default oil pressure........
I have low oil pressure at idle. On the scale where its says normal the needle is on the L. It's half way while driveing. 124,000 miles on motor, but runs strong. Any ideas?????????????
Old Sep 16, 2005 | 08:37 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: oil pressure........
It could be that your oil pick up is clogged. In this case you'd need to drop the oil pan and clean the pick up line. But wait for some other responses and try easy things first, this job is a PITA.
Old Sep 16, 2005 | 11:24 PM
posnick's Avatar
posnick
if the needle is at the L that is on the way high side. if its in the middle when driving, totally normal. but if it seems off to you or fluctuates could be the the sending unit
Old Sep 17, 2005 | 01:14 AM
92hatchLX's Avatar
92hatchLX
Mine will flucuate too, except it reads about half way all the time which is normal. The oil pressure is going to fluctuate as you are at different rpms (it's going to be higher at higher rpms and vise versa).
Old Sep 17, 2005 | 02:01 AM
posnick's Avatar
posnick
by flucuate i meant if your on a hiway drive, and it keeps going up and down while maintaining speed
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
