No timing pointer
Old Sep 6, 2012 | 03:22 AM
jughead's Avatar
jughead
Default No timing pointer
I have a '71 302 Ford engine in a '35 MBZ kitcar. Whoever owned the car before me modified the cover over the crank pulley and removed the timing pointer. I need to create a new timing pointer. I assume that I can bring the engine to TDC and make a mark above the crank pulley to use as a timing pointer.
My question: To find TDC do I feel for compression (or get close to it by cycling the engine so that the rotor points to #1 plug wire on the distributor cap) for #1 cylinder, then watch the exhaust valve cycle through, then make my mark above the crank pulley just as the intake valve starts to activate, or do I make my pointer mark when the exhaust valve comes "up" but just before the intake valve goes "down"? I guess I can also find TDC by lining up the cam and crankshaft pulleys then reinstalling the cover and making my mark?
Any suggestions?
Thanks for your help.
Mahalo
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
