fans not working...
Old Sep 7, 2012 | 06:33 PM
mekniker's Avatar
mekniker
Default fans not working...
car starts to overheat due to no fan running....replaced relays...problem intermittant....
Old Sep 7, 2012 | 07:45 PM
Daehawk's Avatar
Daehawk
Wire it to the ignition like I did my old Trans-Am. That way when the switch is on then the fan runs.
Old Sep 8, 2012 | 03:26 AM
Caleb1's Avatar
Caleb1
you could just use a piece of wire to short out the fan relay.. a guy at work did that, don't know how long it worked though.its different for every car out there, he just put a wire where the relay was supposed to be, then put the relay back in, it spun constantly.
Hope.................... this will working your fan.
Old Sep 11, 2012 | 10:41 AM
89fiveeight's Avatar
89fiveeight
good way to burn up your fan motor.
use one of the blanks in your fuse block and wire it thru either your ignition as stated above or to a toggle.
Old Sep 11, 2012 | 01:26 PM
Norman1's Avatar
Norman1
Have checked that the jacks of fans are plugged in or not. it also happens with me a few months before. In those days I have traveled daily. Many times my car goes overheated and I have to take some rest for cool down my car's engine. Then i have know the reason that the car is overheated because the fans are not working and i go to a garage and fix this problem. When the mechanic see the fans he had just plugged the jacks in and the fans are working perfect. Then I felt that i should see this before coming here. so check that.
Old Sep 11, 2012 | 05:32 PM
mekniker's Avatar
mekniker
thanks for the ideas ...will check it out
Old Sep 13, 2012 | 07:20 AM
NickP87's Avatar
NickP87
-Test the fan by connecting it directly to the battery.
-Make sure you're getting power at the plug for the fan. Either a voltmeter or 12v LED plugged into the plug & running the AC should work.
-Test the relay. Make sure it clicks.
-Make sure the relay is getting power on both sides. One side will have a constant 12v source & the other should only have 12v when the fan would turn on (high temp or AC on.)
A few weeks ago I went through this on a Maxima. I went the opposite direction with testing & it turned out to be 2 bad fan motors.
Old Sep 13, 2012 | 11:00 AM
TRexGAWD's Avatar
TRexGAWD
I would just throw on a toggle switch.. turn it on and off whenever you want.
Old Sep 15, 2012 | 08:15 AM
Caleb1's Avatar
Caleb1
Ohh really ?
Old Sep 15, 2012 | 10:29 PM
craig71springsport's Avatar
craig71springsport
Wire it up to a toggle, just don't forget to keep your eye on your temperature. If you want the re-assurance and convenience the whole built in toggle system that the fan originally came with and was designed for, get some replacement wires and re-do it yourself. Would definitely make sure the motors aren't dead though.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
2016PP
Sep 23, 2015 09:51 AM
