Underdrive pulleys
Old Sep 29, 2005 | 07:45 AM
KillSwitchNY's Avatar
KillSwitchNY
Default Underdrive pulleys
i want to buy an underdrive pulley set, they are fairly cheap.
what are the advantages of underdrive pulleys... and the set i want comes with 3 pulleys, what are they for and what belt do i need to get once installed
Old Sep 29, 2005 | 08:18 AM
DR8907's Avatar
DR8907
Default RE: Underdrive pulleys
Underdrive pullys slow down your accessory drives and free up horsepower. Crank, alternator, and water pump pullys come in the set.
Old Sep 29, 2005 | 09:17 AM
02StanGT's Avatar
02StanGT
He's right. It makes the water pump and alternator pulleys bigger, and the crank pulley smaller. Kind of like lightening the load on the engine. There are no disadvantages to them, unless you plan on supercharging it. In that case you actually lose boost. If you plan on supercharging your car, I wouldn't get the pulleys. In my case I didn't need a new belt after having them installed.
Old Sep 29, 2005 | 10:34 AM
Chopper's Avatar
Chopper
Don't buy piggyback pulleys.To retain the harmonic balancer you bolt the stock balancer to the new crank pulley.Steeda and March both offer the SFI approved non piggyback set.Remember to remove the washer under the bolt on the old crank pulley and to use a good bead of RTV in the keyway when installing the new crank pulley.
Old Sep 29, 2005 | 05:36 PM
KillSwitchNY
ORIGINAL: Chopper
these guys on ebay sell all mustang parts and havent had anything bad said about them....
what do you guys think of these pullies? and how much would steeda pully set run if i needed to go with them
Old Sep 29, 2005 | 05:43 PM
KillSwitchNY
actually i just looked on steeda.com and the pully set is 100 bucks, might as well do that instead of paying 80 for some knock off,
i see steeda has a 3" racing crank pulley that you can buy by itself... is that how big the crank pully is in the underdrive set?
Old Sep 30, 2005 | 01:41 PM
Tim37's Avatar
Tim37
you probably don't want a 3" underdrive pulley thats gonna be best for a car turnning serious RPM on a open track or getting the battery charged inbetween rounds at a drag strip.
Old Sep 30, 2005 | 07:52 PM
TinPony's Avatar
TinPony
I am also considering under pulleys. if I go in for warranty will they tell
me I modified it and void my warranty ????
Old Sep 30, 2005 | 08:23 PM
Tim37's Avatar
Tim37
thats all up to your dealer and if they want to be an ars or not.
Old Oct 1, 2005 | 05:16 PM
KillSwitchNY
ORIGINAL: Tim37
alright thats good info...... im actually worried about the alternator frying if i get an underdrive set, my friend said get a 130 amp alternator from a 94-95 gt and splice it in then mabey ill do the pulleys
