Raxiom Headlights
Daughter has 2004 and BF got her new Raxiom Projector headlights. Installation was simple and he did the work. When I saw them today looked good but this evening when on the low beam was very low and 1/2 the light or stock lights. Is there any way to get the low beam to adjust up?
Thanks |
NO IDEA REGARDING THIS BUT I WOULD RATHER SAY TO REFER IT TO NEAREST SERVICE STATION THAT WILL GIVE YOU A VERY BEST SOLUTION REGARDING YOUR PROBLEM,.........
Bosnjak,, you must not work on your car??? dah??????????
I would think there would be an adjustment at the top of the light like the stock ones.
Originally Posted by runnhrd
(Post 8120853)
Thanks Shane |
https://mustangforums.com/forum/4-6l...ght-beams.html
Here's where the vertical adjustment is for your headlights. From experience, do not over turn them or they WILL break. If the are still too low after adjusting them up all the way you may need to pull the headlights out out and shim/bend the appropriate mounting point it to get the light at the level where it should be. |
how are the raxiom lights at night?
