Sponsored by:
Sponsored by: DashLynx
Play in steering wheel
Old 02-18-2013, 08:48 PM
00blackstang
00blackstang's Avatar
Default Play in steering wheel
There is slight play in my 88 lx steering wheel. The play is def comming from around the wheel itself. It there a steering wheel nut under the wheel like other cars? Possibly this could b loose.
00blackstang is offline
Old 02-18-2013, 10:11 PM
Randynj
Randynj's Avatar
Is it a tilt column? If so, the play may be coming from the hardware holding the tilt assembly together.
Randynj is offline
Old 02-18-2013, 11:54 PM
petrock
petrock's Avatar
There are alot of components in the steering system that can cause this problem. Wiggle the steering wheel back & forth and look at what is moving and what is not. The problem is at the first joint where one side rotates and the other does not. It could be the steering column, could be the intermediate shaft rag joint, or inner/outer tie rod(s). Good luck...
petrock is offline
Old 02-19-2013, 09:14 AM
Randynj
Randynj's Avatar
Also good advice. You have to determine is that area of the column is jumping around? Or do you just have play farther down the line
Randynj is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
BOBCATJACK
09-14-2015 02:18 AM
09-08-2015 11:50 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Play in steering wheel
