Rear conversion
Old Oct 2, 2005 | 06:39 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Rear conversion
need some help on a 5 lug rear disc conversion
what will i need to do to keep my stock rear yet convert to 5 lug rear disc?
i know i will need the axles but will everything else such as calipers and brake lines bolt right up???
also after the conversion i will be doing 373 gears.... do you need to change anything else besides the gears itself to do this
Old Oct 2, 2005 | 06:47 PM
OneGearhead's Avatar
OneGearhead
Default RE: Rear conversion
youll probably need a more powerful master cylinder to handle the increased pressure. as for the gears, i think all v8 'Stang axles are 28 spline, so, shouldnt have a problem......unless youre just gonna upgrade axles to a 31 spline, then, youll need a 31 spline carrier or locker. good luck. let us know how it turns out
Old Oct 3, 2005 | 01:05 AM
DaGGer's Avatar
DaGGer
if i was you, don't bother trying to change it over that way. get a turbocoupe or a cobra rear end they have rear disk brakes and go straight in.
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
