help me please!!!
Old Oct 2, 2005 | 11:30 PM
1992mustangzex's Avatar
1992mustangzex
Default help me please!!!
Im getting a miss it only happens sometimes. I can drive for an hour and it will be fine, then park and drive again and it does it. I have changed my fuel filter, checked my wires new plugs, cap, rotor, cleaned my MAF and checked my TPS,i have also checked for vacum leaks. and 2 new O2s.timmings at 10 dig, lots of fuel injector cleaner. i had 3 codes on the computer 31 41 91, after i changed the o2s i cleared the codes and its bin a week and they havent come back. it never happins when the car is cold and and WOT. If i sit in neutral and rev it passed 4 grand it will miss too. please give me some help the car runs perfect besides this stupid miss. my fuel pressure is at 41 at idle, it misses at idle 2 somtimes. thanks alot
bbk headers, taylor wires,2.5 inch magnaflow mufflers h pipe no cats. 100 zot no2.
13.5 at 107mph
Old Oct 5, 2005 | 03:58 PM
fordguy17's Avatar
fordguy17
Default RE: help me please!!!
you said you "checked" your wires. have you actually replaced them?
they could still be arcing...
Old Oct 5, 2005 | 04:27 PM
angcobra's Avatar
angcobra
Do you have an aftermarket ignition box or coil? These help the most when the engine is hot and at high RPM.
Old Oct 15, 2005 | 08:14 AM
StangGT_90's Avatar
StangGT_90
hmmm, i'd definately check the entire ignition system and make sure every part of it is working properly!!!
Old Nov 6, 2005 | 11:23 PM
90gtmustang's Avatar
90gtmustang
hey i am having the same problem someone told me that it could be the head gasket but i having taken the time to look yet what do you think?
