answer maybe??
Old Dec 18, 2003 | 01:56 AM
primetime5.0's Avatar
primetime5.0
Default answer maybe??
when i push the clutch in my rpm's jump for about 10 sec then drop, anyone know what the deal is?? or do i have to keep asking till someone does
Old Dec 18, 2003 | 02:28 AM
T5superduty's Avatar
T5superduty
Throw-out Bearing?</P>
Old Dec 18, 2003 | 12:58 PM
primetime5.0
its all new, flywheel,clutch,bearing,clutch cable everything clutch related
Old Dec 18, 2003 | 02:47 PM
98 CobraSVT's Avatar
98 CobraSVT
push your clutch in down shifting? or revving up?? little more info please.
Old Dec 18, 2003 | 06:59 PM
primetime5.0
pushing to clutch pedal in, rpm's jump up then drop after a bit
Old Dec 18, 2003 | 07:07 PM
Pitviper100's Avatar
Pitviper100
mayb something is sticking together when you push in th clutch
Old Dec 18, 2003 | 07:29 PM
95Stealth302's Avatar
95Stealth302
Your clutch needs to be adjusted. But defining the problem depends on if the RPMs jump when you push the clutch in while in gear, or just from a stand still. If its while your in gear, then your throttle cable is too tight, and you're not letting off the gas early enough. Sounds like when the clutch pedal is out, the clutch may be still rubbing on the pressure plate or whatever and that it isnt released fully, so when you push the pedal in, it finally releases, thus releasing the tension on the driveline, and causing the engine to spin freely again. Tell us if it happends when in gear or in neutral, or both.
Old Dec 18, 2003 | 09:15 PM
primetime5.0
when im shifting into any gear it does it
Old Dec 18, 2003 | 11:28 PM
95Stealth302
That would lead me to go with the first theory. That either your throttle cable is too tight, and your foot is what is causing the jump in RPMS, or that your computer is at the forefront of the problem. Does the RPM jump and stay at a certain number or does it just jump up and then slowly come back down?
Old Dec 19, 2003 | 12:25 AM
primetime5.0
its jumps and stays at a certain rpm, and when im shifting i dont have my foot anywhere near the gas pedal
