Front suspension/brakes
Old Oct 6, 2005 | 03:29 PM
Bernard's Avatar
Bernard
Default Front suspension/brakes
Was wondering if anyone had the experience of changing over a 67/68 fastback front end from drum brakes to disc? Can the struts, spindles, rotors and calipers be swapped over from a late model GT stang (what years?) on to the 68? Does one have to change to a newer upper control arm as well with negative roll and correct the bumpsteer associated with these older suspensions?
Old Oct 6, 2005 | 04:31 PM
Tim37's Avatar
Tim37
Default RE: Front suspension/brakes
75-79 Granada front spindles disk and calipers.
Old Oct 6, 2005 | 05:18 PM
Bernard's Avatar
Bernard
Thanks Tim. Is that the only way to go or do you know if late model mustang stuff works or is it the same?
Old Oct 6, 2005 | 05:50 PM
Tim37's Avatar
Tim37
i think fatman http://www.fatmanfab.com/ makes a kit to put fox struts spindles and rotors but i am not sure if not they will have a mustang 2 front end. the granada swap is the cheapest and easiest in the long run the after you get your spindles and caliper brackets, the only thing you can't buy at your local parts store is the rubber lines. Those won't be that big of a deal any vintage mustang parts vendor will be able to get what you need.
breaking
Oct 2, 2015 01:27 PM
winner99
Oct 1, 2015 01:06 PM
winner99
Oct 1, 2015 10:52 AM
mdg
Oct 1, 2015 07:04 AM
UrS4
Sep 30, 2015 10:13 AM
