Magnetic Oil Drain Plug
Old Oct 10, 2005 | 04:00 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Magnetic Oil Drain Plug
Ok i saw these magnetic oil drain plugs that supposedly are super strong. they claim to attract metals and so on in the oil.
i think it is far fetched being that the oil is thick and the speed that it is travelling is probably too fast to let the magnet catch anything.
although while the car is off i could see it picking up metal particles floating near it in the oil.
has anyone used a magnetic oil plug???
give me your input here
Old Oct 10, 2005 | 04:13 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Magnetic Oil Drain Plug
Yes may car came stock with one. What you will see is a powder that is on the magnet, this is actually dust from the bearings and rings, if you see anything bigger than a fine powder you have big problems.
Old Oct 10, 2005 | 04:14 PM
awnumber1's Avatar
awnumber1
ive always heard that its a good idea to have one, i do , but if your motor is making metal shavings big enough to see, a magnetic drain plug wont do you anygood cause your gonna have a serious problem pretty soon.
Old Oct 10, 2005 | 04:28 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: awnumber1
Matter of fact, it's a GREAT idea. Just stay away from the magnets for your fuel line. That's a scam that can do damage.
Old Oct 10, 2005 | 07:31 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: KillSwitchNY
Anything that helps to catch what the oil filter misses is a decent idea. A magnetic drain plug works fine. Your differential fill plug has one in the rear end.
Old Oct 10, 2005 | 08:21 PM
02StanGT's Avatar
02StanGT
ORIGINAL: Derf00
I was going to mention that . A magnetic oil drain plug is a good thing to have as others have said.
Old Oct 10, 2005 | 08:36 PM
JT2000's Avatar
JT2000
So where do I find one?
Old Oct 10, 2005 | 09:24 PM
03YellowPony
Auto parts store. Actually, I think the dealer will probably have them in stock.
Old Oct 10, 2005 | 10:23 PM
kartracer55's Avatar
kartracer55
Yeah magnetic drain plugs are a good saftey measure... it does most of its catching when the motor is off and the oil is settling.
Jim
Old Oct 11, 2005 | 12:19 AM
KillSwitchNY
good thats all exactly what i wanted to klnow before i went and spent 15 bucks on one. ill probably pick one up next week. but DAMMIT, i JUST did an oil change last week.... haha i guess ill have to either wait or pull the old plug fast....
i think i will buy 2 of them since there is the other oil drain plug on the front of the pan... and extra magnet couldnt hurt
