Blown Rear Differential - Central NJ
Old Mar 13, 2014 | 02:43 PM
SilverStang2014's Avatar
SilverStang2014
Default Blown Rear Differential - Central NJ
I need to replace my rear differential on my 2001 mustang V6. I took my car to freedman auto and they quoted me $1100 for a Junkyard differential
Looking for a good Mustang mechanic around Central NJ.
Old Mar 14, 2014 | 06:43 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Describe "blown", what's it doing that it can't be rebuilt?
Old Mar 14, 2014 | 08:07 AM
SilverStang2014
Over 35 mph the car start shaking all over the place. Also, there is weird noise coming from the assembly.
That the whole reason I need a good mechanic. Who can diagnose the actual problem and replace wheat needed.
Old Mar 14, 2014 | 07:11 PM
lindertw's Avatar
lindertw
holy cow, for that price I would swap in a http://www.ebay.com/itm/FORD-RACING-2005-2012-MUSTANG-GT-3-55-AXLE-ASSEMBLY-31-Spline-Axles-M-4001-A355-/250993244103?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a705cf7c7&vxp=mtr
good luck!
Old Mar 17, 2014 | 06:51 AM
88 orangepeel notch
I would look into a bad u- joint or bent rim first.
Old Mar 23, 2014 | 05:07 PM
SilverStang2014
Default BAD Motor Mount
Its wasn't the differential.
It was suggested it was the transmission mount.
Replaced the above mounts and still there is vibration..
severe shake between 35-35 mph.
This is driving me nuts.
Old Mar 23, 2014 | 05:15 PM
SilverStang2014
Fuel Filter - Replaced
Coil/ Plus/Wires - Replaced
Rim and Tires - OK
Trans Mount - Replaced
U-joint - Ok
Drive Shaft - Ok
Old Mar 24, 2014 | 08:04 AM
88 orangepeel notch
Well if everything checks out ok, then maybe there's a bent axle or tweaked hub or something else internal but I've never personally heard or seen one cause a bad vibration at such a low speed.
$1100 seems a bit steep for parts and install, but maybe prices differ alittle to location. If your mechanically inclined, replacing a rearend is not that hard of a job to tackle it yourself. You'd save yourself $500-$600 for 3-4hrs of wrenching if it's your first time. Assuming a used rearend is $400-$500 around you.
Good luck and keep us posted on the outcome, just to help the next guy with similar troubles.
Old Mar 24, 2014 | 05:32 PM
SilverStang2014
the problem is ... Mechanic have become parts swappers. I will take the car this weekend to Valley performance and hope fully post the autocome
mtgldr
Feb 3, 2024 09:00 PM
GTJIM
Sep 23, 2015 09:59 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Sep 16, 2015 07:53 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
