General question
Old Mar 23, 2014 | 11:02 AM
JJRJR's Avatar
JJRJR
Default General question
Hey guys, just joined. We are at stage one of an engine build. Not sure what car we'll put it in, but likely an 89 to 91 Mustang LX. For starters, we sort of wanted a 351W, but they aren't easy to find.
Can a put a 460 big block in those Mustangs? How heavy can you build a 302? They are plentiful and I hear cheaper to build. Probably would like about 450 to 500 HP for street use eventually.
Thanks all,
John
Old Mar 24, 2014 | 08:38 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Yes, there are actual swap kits that allow you to drop a 460 right in, but your also dropping in alot more weight which I read can unbalance the handling if not set up.
A factory 302 can handle 450-500 hp at the crank if built right.
Old Mar 26, 2014 | 02:15 PM
poxenham's Avatar
poxenham
302 is a good engine thats easy to get ahold of, you can definitely get the power you're looking for out of it with the right parts. Look at other people's builds and see what they used to get whatever amount of power and go from there. The 460 big block is heavy so it will take a lot of suspension work for the car to handle half way decent.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
