Bent Frame
Old Oct 14, 2005 | 11:46 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Bent Frame
Ok the part of the frame under the grill and by the radiator fan is bent inward how hard would it be to pull out or bend back
Old Oct 15, 2005 | 12:41 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Bent Frame
Not hard at all but if that part is bent it might be bent elsware and you can't tell. You can have put on a frame machine and straightend out no problem
Old Oct 15, 2005 | 12:50 AM
ByPopularDemand
Thank you JD BTW its a 2000 V6 how much do you think straightening would run
Old Oct 15, 2005 | 11:02 AM
pj1010's Avatar
pj1010
MY local body shop quoted me approx. $250 to straighten things out.
Old Oct 15, 2005 | 11:22 AM
Sidewayz6.0's Avatar
Sidewayz6.0
I dunno, I might have seen that exact thing done with a chain and a Grand Cherokee...
I wouldn't suggest trying it though. It's probably only $100-$200 to put the straight the right way.
Old Oct 15, 2005 | 12:11 PM
GreyStang's Avatar
GreyStang
A pic would be helpful here
Old Oct 15, 2005 | 12:40 PM
vfast's Avatar
vfast
I ♥ Acer
depends how bad as a new rad core support might need to be replace....wine wasn't bad and had a friend pull it on the front machine he charge me the friendly rate*L*
Old Oct 15, 2005 | 02:29 PM
Tim37's Avatar
Tim37
ORIGINAL: Sidewayz6.0
how about a tree and a winch.
Old Oct 15, 2005 | 04:46 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: Tim37
my ex rear ended another car in my camaro and I didn't want to put it through insurance so I used a chain and a post on the front of my house.....put the car in reverse and pulled it too far so I had to gently bump it off the post again until it was just right LOL.
BTW - never buy a car from me
Old Oct 15, 2005 | 05:12 PM
Tim37's Avatar
Tim37
damn canadians
i have seen that done too i have a couple of friends that do body work. some of the crap i have seen pulled amazes me.
