Front end shakes
Old Oct 4, 2014 | 01:14 PM
Hawkeye's Avatar
Hawkeye
Default Front end shakes
2000 mustang GT Conv. Front end and steering wheel shake when braking hard at about 60 mph and above. You can't feel it in the brake pedal. Front rotors pads and calipers have been changed. Also new tires and struts. Tried different front tires and wheels with the same result. Any ideas?
Old Oct 4, 2014 | 08:21 PM
yourmom6990's Avatar
yourmom6990
needs an alignment or new wheel bearing
Old Oct 5, 2014 | 02:08 PM
XD40Colorado's Avatar
XD40Colorado
YourMom-
SWEET car. Does the Air-Raid CAI make a difference in acceleration do you think? Thinking about getting one.
Old Oct 5, 2014 | 04:10 PM
Hawkeye's Avatar
Hawkeye
Car tracks perfect and doesn't drift. There's no play or roughness in the wheel bearings. I've checked all the obvious. I was hoping someone had the same problem and found a solution.
Old Oct 5, 2014 | 08:08 PM
yourmom6990
Originally Posted by XD40Colorado
YourMom-
Thanks. It makes a difference throughout the whole RPM range. Really changed the sound as well. Worth every penny.
As for the OP, It could be a number of problems. My guess would be the rotors but since you've replaced them, not sure how it can be an issue. Take it in and have someone diagnosis it. Could be as simple as an alignment.
Old Oct 6, 2014 | 07:33 AM
88 orangepeel notch's Avatar
88 orangepeel notch
I also think it's time to bite the bullet and take it to a trusted mechanic. Throw it on a rack look for worn bushings, ball joints, etc.
It'll be money well spent in the end.
Old Oct 6, 2014 | 11:10 AM
dlazrael's Avatar
dlazrael
I had a wicked shimmy in mine, ended up needing grease in the bushings on the sway bar (aftermarket sway for me)... still has a little shimmy but I also know I'm out of balance, one of the weights fell off yesterday... but greasing the bushings solved ALOT of the shimmy...
Good Luck
Old Oct 10, 2014 | 12:36 PM
tychotb's Avatar
tychotb
wheel bearing?
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
