96 drivers power window inop
Old Oct 30, 2014 | 09:32 PM
smenzel444's Avatar
smenzel444
Default 96 drivers power window inop
my 96's drivers side power window quit working.
I have power out of the switch, but it doesn't make it to the motor.
The passenger side works fine and the left side motor works when 12v is applied via a jumper.
Please Help
Old Oct 31, 2014 | 06:19 AM
88 orangepeel notch's Avatar
88 orangepeel notch
If your sure you have power coming out of the switch, then I'd look for a break or pinch in that wire to the motor. There has to be something that's not allowing power thru. Good luck
Old Oct 31, 2014 | 09:01 PM
smenzel444's Avatar
smenzel444
Default Thanks for the reply
The wire from the switch joins a bunch of other wires that are wrapped pretty well. I can't see any damage without unwrapping it all. I was wondering if there is some fuses, relay etc. I'm missing before I unwrap the harness. My Chilton's manual has a lot of schematics, but not that one. If anyone can turn me on to one that would help greatly.
Old Nov 4, 2014 | 08:42 PM
AzPete's Avatar
AzPete
If it is a one touch type, there maybe a box inside the door panel that controls that. My grandsons 93 Explorer had that issue and we sourced a good box from a pick n pull.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
