Mach 460 amps??
Does anyone know where the Mach 460 amps are in a 1994 Convertible?</P> I've read that the Coupe has the amps mounted under the rear deck. But obviously that's imposible in a Convertible.</P> THANKS!!!!</P> |
Mach 460 amps??
Probably in the trunk were the rear deck would be. Not pretty things just silver colored boxes.</P> |
Mach 460 amps??
behind the rear speaker panels on each side of the rear seat?
Mach 460 amps??
how do u know if u have a mach system?</P> in a convertable</P> |
Mach 460 amps??
you'll have the tweeters on the front doors where the mirrors are, just like on the coupes
Mach 460 amps??
There should also be a third amp mounted to the hump inside the dash. Pull the decks out and you will see it down at the bottom.
Mach 460 amps??
yea i dotn have one LoL o well im puttin in my system this week a pioneer head 2 12s and a 8oo watt amp somethin should crank
Mach 460 amps??
They are right behind the rear seats.
Mach 460 amps??
There is nothing in the trunk. There is no rear deck. There isn't anything on the sides of the inside of the trunk.</P> I guess I could try to look behind the rear side panels, where the rear/side speakers are on a convertible.</P> A third amp under the dash/in front of the center consol? Why? what speakers does it drive?</P> |
Mach 460 amps??
The third amp drives the 2 1/2" tweeters.
