knocking!!
Old Jan 21, 2015 | 07:18 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Good point, but the load on the motor determines the load put on the bearings. For example, at light load, say in neutral, you rev to 2000 rpm and hold it there, this is a light load where the motor isn't working and the crank bearings would be making a lot of noise if they were bad. This isn't a great explanation, but I'm not a poet, or a mechanic by trade lol.
Old Jan 21, 2015 | 03:32 PM
v6power88's Avatar
v6power88
I'm sorry for the bad description, im trying my hardest to explain. This noise just makes me nervous. I'm just trying to avoid paying $100 for a diagnostic. Can I upload a video of what it sounds like?
Old Jan 21, 2015 | 07:58 PM
cruisin5268d's Avatar
cruisin5268d
Are you willing to ruin your motor for $100?
Old Jan 21, 2015 | 08:32 PM
v6power88's Avatar
v6power88
In pretty sure you know the answer to that question. I'm trying to determine if it's something that could be fixed simply due to something loose or whatnot, or something I can diagnose myself without spending money I don't have. Hence, why im on this forum. Thank you.
Old Jan 22, 2015 | 07:30 AM
88 orangepeel notch
A video may help, depending on the quality of sound. I'd verify oil pressure first, as that will let you know right away. Good luck, hopefully it is something simple, but don't get your hopes up.
One thing that's odd is that you said this noise goes away above a certain rpm. That's a good thing.
Old Jan 22, 2015 | 01:20 PM
v6power88's Avatar
v6power88
I'm gonna start by doing oil pressure test like you suggest and see i everything is reading good. If problems persist Im just gonna have to admit defeat and bring it in lol. I appreciate all your help 88orange!!
Old Jan 22, 2015 | 03:56 PM
88 orangepeel notch
No problem, good luck
Old Jan 26, 2015 | 03:01 PM
alfred9744's Avatar
alfred9744
My o1 has made the same noise awhile now,at least a year it is coming from the timing chain tensioner,having it replaced soon. I used a stethoscope to track it down.
Old Jan 27, 2015 | 01:32 AM
SyNdicateZ's Avatar
SyNdicateZ
You need a valve job. One of your cylinders is shot. Do a compression test
Old Jan 27, 2015 | 11:28 PM
v6power88's Avatar
v6power88
How do you know exactly that it's the timing chain tensioner??
