knocking!!
Old Jan 27, 2015 | 11:28 PM
  #21
v6power88's Avatar
v6power88
Originally Posted by SyNdicateZ
You need a valve job. One of your cylinders is shot. Do a compression test
And compression is fine and noise isn't coming from that area.
Old Jan 28, 2015 | 05:13 AM
  #22
alfred9744's Avatar
alfred9744
Someone else had same Issue and it was chain tensioner.mine has been making that noise 4 a year. Car runs fine except the noise drives u crazy. Shop says 6.5 hr job.quote for repair 1100 dollars. Ouch.I hthink i might try an fix it myselfmyselrepair manual says u need to drop the oil pan,looks like a pain in the ***.Not sure about pan though.noresponse to that question yet.I should just go to Ford for a diagnosis.if I do i will let u know
Old Jan 29, 2015 | 04:50 AM
  #23
v6power88's Avatar
v6power88
Please do let me know. I have also been looking into the chain tensioner as I have heard the same.
Old Jan 30, 2015 | 04:56 AM
  #24
alfred9744's Avatar
alfred9744
I will let u know.I have been trying to find out if you need to drop the oil pan to get the timing cover off.no one has replied yet.have heard you need to pull the pick up tube for oil pump which bolts to block inside the oil pan.
Old Jan 31, 2015 | 06:17 AM
  #25
v6power88's Avatar
v6power88
I believe the timing cover unbolts right off without removing anything. Just remove serp belt and dampeners then cover. For the 3.8 at least.
jessicarabbit
Sep 25, 2015 12:41 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
degner122
Sep 16, 2015 07:09 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
