Installing sparkplugs
Old Oct 20, 2005 | 06:36 PM
99mustanggt's Avatar
99mustanggt
Default Installing sparkplugs
Hi everyone,
I just got new sparkplugs for my 99 GT but when i installed the first one it only went in about 2 turns. I took it out and re-installed it 2 or 3 times and it did the same thing everytime.I just wanted to see if this is normal before i continue with the rest of the plugs.Any info will be greatly appreciated. Thanks
Old Oct 20, 2005 | 06:58 PM
mustang_montana's Avatar
mustang_montana
Default RE: Installing sparkplugs
you may have messed up the threads because they shouldn't have any trouble going down. whatever you do dont force it down.
Old Oct 20, 2005 | 08:24 PM
TorchV6's Avatar
TorchV6
agreed dont force it cuz then you will have to tap it and the shavings unless using a vaccuum and even then no gaurantees that the shaving wont go into the engine. So try to feel the threads on the block and check the threads or try a different plug in that hole if they are screwed up I feel bad for you even though its not a MASSIVE deal it still sucks real good.
Old Oct 21, 2005 | 05:48 PM
Chopper's Avatar
Chopper
You might have to use a sparkplug hole thread chaser.This will clean up the threads and allow you to install the plugs.By the the way you describe your problem my guess is the plug is cross threaded.You can coat the chaser with grease to catch the cuttings and keep them from falling into the engine.GO SLOW,if the plug is cross threaded the chaser can be also.If it goes in crooked it will tap new threads and ruin the old ones.Then the plug won't be able to be tightened to full torque and will eventually pop out.The only remedies for this will be to Helicoil the spark plug hole or head replacement.
Old Oct 21, 2005 | 06:28 PM
GreyStang's Avatar
GreyStang
Did the other 7 go in OK? You should be able to screw them all the way in with just your fingers..
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
