Oil pressure switch
Old Nov 29, 2015 | 01:21 PM
dario0341's Avatar
dario0341
Default Oil pressure switch
have y'all seen an oil pressure switch that looks like the one in the picture that I have attached? It goes on a 71 mustang Fastback. 1 line is to the fuel pump 1 is to the gauge. Not sure bout the third. If so where can I get one. I have checked several places and have had no luck. Thanks in advance
Old Nov 30, 2015 | 07:48 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Welcome to the forum. Try starting a new thread in the Classics section. They may be able to help you out. Good luck.
Old Nov 30, 2015 | 07:45 PM
dario0341's Avatar
dario0341
Thank you for the response. Very sweet sounding ride.
Got a 331 stroker, balance Windsor Jr heads, comp magnum 284h cam, maule pistons, canton windage tray and main cap support, scat crank, Erson forged aluminum roller rocker arms, 600 street avenger Holley carb, C4 automatic transmission with TCI breakaway torque converter, hurst ratchet shifter, 8 inch ford limited slip rear end with 3.50 gear ****. Paint is decent but overall still have a lot I need/want to do!
Old Dec 2, 2015 | 07:41 AM
88 orangepeel notch
Sounds nice, congrats on that setup.
Just curious, you said one of those wire runs to the fuel pump ? I'm assuming that it's just a ground for the pump. But I don't know why they'd do that when the block or frame would be a better ground.
Old Dec 2, 2015 | 07:23 PM
dario0341's Avatar
dario0341
It does run to the fuel pump and acts as an emergency shut off for the fuel pump as well as a **** off for the oil pressure
stangxtreme
Oct 24, 2015 09:42 AM
fullmonte60
Oct 5, 2015 11:29 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
schecterplayer
Sep 23, 2015 08:38 AM
