Fuel Gauge Reading
Old Aug 28, 2016 | 05:05 PM
LuckyM95's Avatar
LuckyM95
Default Fuel Gauge Reading
I am having trouble figuring out why my fuel gauge/fuel sending unit won't work correctly. I took out my sending unit and placed it in the fuel position but it only reads between a 1/4 tank and 1/2 tank. When I place it in the empty position, it reads empty. Anyone know why this is? I pictures of the gauge in both positions if needing to show. Btw, I have an Aeromotive 1000 tank with AutoMeter gauges.
Old Aug 29, 2016 | 07:19 AM
88 orangepeel notch's Avatar
88 orangepeel notch
There's probably a short in the rheostat windings in the sending unit. Are they still original yet. This is a fairly common issue in Foxbodys. My 88 does the same thing at 1/4 tank. It'll temporarily read full till if drops to 1/8 tank then it's back to normal. I'm living with it.......lol
Old Aug 29, 2016 | 10:00 PM
LuckyM95's Avatar
LuckyM95
Thank you 88. My Aeromotive tank with the components it came with are new but they did sit for a long period of time before being used. This problem occurred right after everything was hooked up. Maybe I have a defective part. I might have to call Aeromotive to see if I can get a replacement part.
Old Aug 30, 2016 | 08:25 AM
88 orangepeel notch
Yep, that wouldn't hurt to try. Good luck and keep us posted....
Old Nov 27, 2016 | 08:22 PM
Vader GT's Avatar
Vader GT
Hello to all, I'm going to revive this thread as I'm having similar issues. My fuel gauge stopped working about 3 months ago & I've been using my trip meter to keep track of my fuel level. So this weekend I bit the bullet & swapped out my fuel sending unit thinking this was the culprit. I also found the harness was in horrible shape so I replaced that as well.
To recap, I changed out my sending unit & harness. I still have NO fuel reading. When I put the key on it goes almost to 1/2 way then the needle just falls to empty. As the car runs it stays on empty. Any advice on what could be my issue???
Thanks in advance!!!
Old Nov 28, 2016 | 08:43 AM
88 orangepeel notch
I'm no expert on these, but did you test the sending unit with a sweep test and a multimeter before installation ? Just to verify it is good before putting it all back together. I've learned new parts don't always mean good parts lol.
Otherwise I'd just verify wiring again as it seems to be getting power just not giving an accurate reading.
Nice looking Notch by the way.
Old Dec 2, 2016 | 08:47 PM
Vader GT's Avatar
Vader GT
orange peel thanks for the reply & the compliment!! I've been out of town so I have not had a chance to mess with it again; I will tomorrow. I'll check everything & make sure it's getting power.
I'm also wondering if it could be the slosh module:
https://lmr.com/item/LRS-10849/90-93...tage-Regulator
I just don't want to spend money if I don't need to. I'll update tomorrow.
Jonathan Davis
Feb 20, 2016 11:14 PM
baileed
Mar 7, 2008 12:56 AM
vfast
Oct 10, 2003 09:50 PM
vfast
Jul 31, 2003 06:54 PM
vfast
Jul 24, 2003 04:29 PM
