289 Pulley
Old Aug 30, 2016 | 10:29 PM
winston57's Avatar
winston57
Default 289 Pulley
my water pump pulley keeps cracking out on my 1966 mustang, its a 289 engine, cracks around the mounting bolts, i have had pulleys lazer aligned , have stamped steel pulleys, what could be causing this?? need help thanks
Old Aug 31, 2016 | 10:57 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Have you replaced the water pump yet ?
Old Aug 31, 2016 | 11:22 AM
winston57's Avatar
winston57
have not replaced water pump, new engine build, about 1800 miles on engine and pump
Old Sep 7, 2016 | 12:19 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Lazer aligned? Never heard of that but the world is full of things I have never heard of.
First thing I would check is to make sure you have a matching set of pulleys and brackets. 1969 and prior or 1970 and later. Make sure you have a matched set because you can drive yourself nuts mixing and matching pulley and bracket parts from different eras. Also verify that your water pump snout is the correct length.
You said that it keeps cracking which leads me to believe that this isn't the first pulley to do this. That tells me that you have some serious stress pulling the wrong way on that pulley.
Gothere
3.7L V6 Technical Discussions
18
May 25, 2017 08:51 PM
Vader GT
Mar 2, 2016 01:19 PM
epicsupercoolian@gmail.com
Feb 24, 2016 01:06 PM
Feb 22, 2016 12:37 PM
Feb 22, 2016 12:30 PM
