Won't idle
Old Oct 25, 2005 | 11:11 AM
Ford68pony's Avatar
Ford68pony
Default Won't idle
Okay, need some suggestions on this one. I fiddled with the carb to smooth out the idle and it worked. Only problem now is that it won't stay idling. It'll work great if I am in the car and have the accelerator pressed down. Also found out while driving it doesn't like the lower RPM's (seems this pony wants to gallop, not trot). It'll run in the lower rpm's but the lower I go, the more it coughs. Once I stop, the pony does too...... So far trying to set the carb hasn't done anything to help.... Any ideas would be grand cause I usually drive this thing to work, and now I have to go around sporting in my wife's mini-van. (Ewwwwwwww) [:'(]
Old Oct 25, 2005 | 02:08 PM
Tim37's Avatar
Tim37
Default RE: Won't idle
did you readjust your idle screw?
you may also have it a little lean causing it to starve for fuel at idle.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
MacSerio
Sep 27, 2015 01:05 PM
