thermostat bolts
Old Jul 26, 2017 | 10:37 PM
my68's Avatar
my68
Default thermostat bolts
need help on the length of the thermostat bolts on a 289 engine thank you
Old Jul 28, 2017 | 12:25 AM
imp's Avatar
imp
Do you have the thermostat housing? The "ears" are about 7/16" thick, add gasket, perhaps 1/16" max., you don't want the bolts to "bottom" in the threaded holes in the intake manifold
(though some go CLEAN THROUGH, and you should check that with a skinny round instrument, a small screwdriver will work. Poke it in each hole; if it "bottoms" put a thumb over it at the manifold surface to measure how deep the hole is.
Bottom line is, use bolts 1" long, they are 5/16-18 in size, if I recall correctly.
If either hole, or both, go through into the coolant cavity behind, coat the bolt threads with sealer before assembling. Permatex #2 is good, or RTV Silicone rubber. imp
Old Jul 28, 2017 | 01:51 PM
my68's Avatar
my68
thank you , i have a chrome water pump on my car that was giving me clearance for the bolts i started them through the housing but wasnt room i ground them off very slightly where i could start them i didnt want to take the water pump off it worked thank you for your speedy reply
