Is 5 lug worth it?
Old Oct 27, 2005 | 01:27 PM
firststang@17's Avatar
firststang@17
Default Is 5 lug worth it?
I am contemplating whether or not to switch to 5 lugs on my 87 gt. So all of yall that have done the converion is it worth it? Feedback Please!!!!!!!!
Drive hard, Drive fast, Drive smart!
87 GT
347
5 speed
a lot done
Old Oct 27, 2005 | 01:35 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: Is 5 lug worth it?
i got the 2 drums and 1 axle.. 28 splines you need another short axle out of a ranger thats all ,,its not nessary iam runing 9on 31 splines moser axles.on 4 lugs
Tim37's Avatar
Tim37
It really gives you a lot more options when it comes to breaks and wheels.
if your running a set of 15" drag wheels and mainly drag i don't think it is but if you wan't some nice looking wheels or big brakes for the street or racing curves it is very well worth it.
Old Oct 28, 2005 | 01:50 PM
firststang@17
i use the car street mostly and maybe a couple trips to the track a year. They do have 4 rear disc conversion dont they?
Old Oct 28, 2005 | 05:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: firststang@17
If you can find a four bolt rear disk conversion, let us know about it, because I don't believe there is one.
Old Oct 28, 2005 | 06:51 PM
Tim37's Avatar
Tim37
im not sure what it came out of but i saw a 8.8 rear with 4 lug disk at a swap meet once i though he wanted a little much.
Old Oct 29, 2005 | 02:42 AM
firststang@17
Thats horse crap. The braking on my mustang is scary compared to newer cars. I have to be so much more cautious driving the mustang that when i drive my moms rsx. That thing stops on a dime.
Old Oct 29, 2005 | 03:23 PM
Tim37's Avatar
Tim37
doing a 5 lug swap has nothing to do with braking.
a upgraded brake kit has to do with braking.
Old Oct 30, 2005 | 11:23 AM
C/Note's Avatar
C/Note
I ♥ Acer
IF YOU 5 LUGS AND BETTER braking go with newer ranger brakes ,,but will will nedd to chage over to 5 lugs that have bigger drums...
Old Oct 30, 2005 | 01:14 PM
vfast's Avatar
vfast
I ♥ Acer
first add a set of svo calipers thier 76mm vs your 60mm they help a ton and are a direct swap....about 20.00 each at autozone
adding S.S. lines help as do mettalic rear shoes..
