Where are the cowl drains on a 2015 Mustang?
My Mustang has started to leak water on the drivers side floor whenever it rains. I tried looking up where to find the front cowl drains on a 2015 Mustang but I have had no luck searching online. I can only find information on models 2014 and below. Does anyone know where the cowl drains are on a 2015 mustang ecoboost premium or heard of any other reason water would be leaking on the drivers side of this particular model?
2015 was when the platform changed, which is why it's not the same as '05-'14.
Still, they ARE there... Can't find anything on it...
If you take the passenger side cowl cover off, you should be able to look
in and see it.
in and see it.
Originally Posted by Wahab Ali
Hey gravy, I noticed you had the exact same problem as me. I have a 2017 Ford Mustang ecoboost, did you find the solution?
it was just info I found online...)
I have a 2006, which doesn't have this problem;
only the 2015+ seems to
Hey Adam reed, did you find the location for the cowl drain location? If so I would REALLY appreciate your help on telling me how to access them
before they paint
check that they aren't loose
