Limited slip additive
Old Oct 30, 2005 | 11:07 PM
Ian70mustang's Avatar
Ian70mustang
Default Limited slip additive
What does it do?
does it allow the diff to slip more than with just gear oil or less?
How can I make my auburn posi slip less?
Old Oct 30, 2005 | 11:42 PM
03YellowPony's Avatar
03YellowPony
Default RE: Limited slip additive
ORIGINAL: Ian70mustang
What does it do?
Did you not put it in when you put the posi in??? If not....look out. It's a friction modifier. Makes the dif fluid so it doesn't ruin the clutch pack in the posi unit. It NEEDS to be in there. Repeat NEEDS TO BE IN THERE!
Old Oct 31, 2005 | 12:07 AM
Ian70mustang
yeah, it's in there, but the rear slips a little more than i'd like. Wondering if putting in half a bottle or two bottles would make a difference. Basically, can i change the slip amount by varying the amount of additive and if so do i put in more or less?
Old Oct 31, 2005 | 01:36 AM
03YellowPony
I've always been told to use only 1 bottle. You might consider changing the fluid to Royal Purple, and 1 bottle of friction modifier. That's what I run. Royal Purple is one of the best gear fluids made, if not the best.
Old Oct 31, 2005 | 01:31 PM
Tim37's Avatar
Tim37
when i changed my fluid it took a week or two for my rear to return to normal i think it just take a while for that stuff to get worked in.
Old Nov 1, 2005 | 01:39 AM
j302's Avatar
j302
the purpose of the friction modifier is to keep the clutches in the diff. from chattering in turns
Old Nov 2, 2005 | 11:24 PM
paniro187's Avatar
paniro187
ORIGINAL: 03YellowPony
royal purple recommend not using firction modifiers when using their fluids. says so on the site mr. 30 plus years blah blah blah
Old Nov 3, 2005 | 02:10 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
somebody let a goat in?
firehorse02
Nov 16, 2015 11:28 AM
TCStangerv6
Oct 11, 2015 05:57 PM
b8checker
Oct 8, 2015 12:55 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
b8checker
Sep 30, 2015 07:11 AM
