5R55S 5th gear lockout.
Old Nov 26, 2019 | 09:47 AM
Damien Acheron Moretz's Avatar
Default 5R55S 5th gear lockout.
So I just bought a 2006 V6 Pony package after my pristine 40th anniversary was destroyed by a tree.
When I first bought the car I noticed that the shocks needed to be replaced, about a month later the motor mounts went and I replaced them. Now it’s starting to get cold outside and every time I drive the shifts are late from 1-3. First thing after starting and letting it warm up it drives a bit sluggish. It shifts perfectly after, but once I get on the highway and have to hit 70 or 80 the rpms stay at about 2,250 to 2,500. I was thinking about changing fluid and filter and maybe replacing the solenoid block.
Old Nov 26, 2019 | 12:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Yep, i would start with maintenance as you've already defined it. Fluid filter and solenoid pack. The 5r55s is notoriously picky over used fluid and being under filled. Be certain to use only Mercon V fluid. Stay away from the universal fluids. DO NOT USE MERCON LV! Wrong fluid and it will ruin the transmission.
Old Nov 26, 2019 | 09:42 PM
Should I go ahead and change the gear oil in the back axle?
Old Nov 27, 2019 | 12:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That would not be a bad idea. That is supposed to be done every 50-75K but since you bought the vehicle used, it won't hurt. Be sure you get the gear oil AND friction modifier if the fluid does not come with any already added. I think the Motorcraft brand gear oil is the only one that comes with the modifier added. Read the label to check or just buy the gear oil from one our site sponsors. They will tell you if if the gear oil you are buying requires any other additives/friction modifiers.
Old Nov 27, 2019 | 01:34 PM
When I bought the car it had 142k and it just recently started shaking pretty bad before I replaced the motor mounts. I was already planning on changing the tranny fluid but got sidetracked. Now since yesterday and this morning it has a slight rattle while idling in drive. And it’s whining while changing gears from 1st to 2nd. I was going to replace the tranny mount while I was doing the motor mounts but I couldn’t get the cross member off the exhaust stabilizers.
Toxix
Oil and Oil Related Topics
23
Dec 21, 2010 08:21 AM
89GTnoob
May 19, 2010 11:01 PM
uberstang1
Dec 18, 2008 07:02 PM
MustangMan00
Oct 20, 2008 11:43 PM
jtmustang
May 21, 2007 08:34 PM
