1998 GT steering wheel moves up, down, and side to side
Old Oct 26, 2020 | 02:32 PM
Dillydilly's Avatar
Dillydilly
Default 1998 GT steering wheel moves up, down, and side to side
I looked around the forum but I couldn’t find anything on the subject. I recently bought a 1998 mustang GT and the steering wheel is able to move up, down, and side to side almost an inch I would say, I know it is probably the upper steering column bearing I was just wondering if there is a fix that doesn’t require removing the whole steering column?
File Type: mov
Old Oct 27, 2020 | 02:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If it's a bearing, probably not. The column has to go through the bearing so it's either gotta be pulled up and out or separated at some point to allow the bearing onto the shaft (column). Never done such a repair so that's my only input.
It's like rear wheel bearings on a RWD car. Gotta pull the axels out from the differential to do them. No other way around it.
Old Oct 27, 2020 | 08:15 PM
SmokyBC's Avatar
SmokyBC
But what kind of worn or failed bearing would give an inch of travel in all directions.
Get a strong light and crawl in there on your back.
wgreenlee4
May 15, 2014 01:24 PM
spiderweb1967
Jun 26, 2011 12:48 PM
jburt80
Jan 13, 2008 04:36 PM
jj86
Dec 16, 2005 10:18 PM
RacerX
Dec 3, 2005 02:24 PM
