White smoke
Old Feb 12, 2021 | 05:34 PM
Recorded's Avatar
Recorded
Default White smoke
I'm not sure if this is a huge issue or I'm just overthinking it. But whenever I turn my car on, there is no white smoke coming out of the exhaust only on one side. Still, when the temperature gauge starts moving, I get white smoke but then once it gets to a certain threshold, it stops, and I don't have overheating issues, and my car doesn't misfire unless I put it under enough strain, I.e., letting the clutch out too quick. The Head gasket was changed in August of this year. I might need to retorque the heads, but I want professional input before deciding to do that because that would require taking the header off and because of how tight a spot it is, I would prefer not to. And if it's not the problem could it be a vaccine leak because there is also a p0171 code (system lean bank one).
Old Feb 12, 2021 | 05:50 PM
Recorded's Avatar
Recorded
Default Just to add
I'm not losing any coolant and if I am, it isn't enough to be noticeable.
Old Feb 13, 2021 | 05:20 AM
David Young's Avatar
David Young
Your on the right track to fix the code. Here is a link for other possibilities that would cause the code.
https://www.fixdapp.com/blog/p0171-code
Ex_boost
2.3L Eco-Boost Tech
Jan 31, 2021 06:09 AM
m87kevin
Nov 20, 2010 02:45 AM
96GTnate
Feb 3, 2009 07:26 PM
WhiteWindsor
Nov 10, 2008 11:48 AM
Guitarhead09
Jul 24, 2006 01:19 PM
