8.8 Rear end question
Old Mar 28, 2021 | 05:07 PM
YetiS197's Avatar
YetiS197
Default 8.8 Rear end question
Recently I acquired a 8.8 rear end. Was informed that gears had been replaced in said rear and were used for 10-20k miles. Got home and tore into it only to find what I believe is a cracked housing. Can anyone confirm? Is it useless at this point?
There’s what appears to be a very noticeable crack between the top oil return port and race sleeve as well a less noticeable pit inbetween the bottom. The race sleeve itself is undamaged but reaching in the ports I noticed the suspected crack goes back in the housing.
Old Mar 30, 2021 | 12:13 PM
imp's Avatar
imp
"Can anyone confirm? Is it useless at this point?"
IMO the crack will propagate diametrically across from the present crack, resulting in failure of the whole works. I have seen cases where the entire carrier casting was cracked entirely in two, due to gear failure. I would not risk it.
Old Mar 30, 2021 | 03:52 PM
YetiS197's Avatar
YetiS197
Upon further inspection with just the eye and a flashlight I’m now question my original statement. Is there a chance that this could just be an impurity in the casting process? I see no visible split, but more of a thin indentation that just happens to appear to be a crack looking at it dead on. I don’t have a microscopes to get a closer look but I suppose I should probably take it in to have it inspected.
Old Mar 30, 2021 | 06:08 PM
JimC's Avatar
Super Moderator
Exactly what I was wondering, No evidence of a leak of fluid from there so perhaps just a casting line?
lbballin9
Jul 23, 2008 01:47 PM
pthurm_28
Dec 9, 2007 04:23 PM
ben5.0
Aug 27, 2006 10:30 PM
jamie660
Apr 19, 2006 01:01 AM
hawks05
South
Oct 21, 2003 08:21 PM
