Trunk vents?
Old Nov 10, 2005 | 02:59 PM
baddog671's Avatar
baddog671
Default Trunk vents?
The other day I was sneeking a peak behind the trunk paneling in the trunk of my 98 stang and I could see light flashes everytime the bass hit on my subs. I couldnt figure out what it was and it did it on both sides of the trunk. So I removed the trunk paneling, I had to anyways so I could get at my taillight assembly, and I found I have vents in my trunk. I put pics in my photo gallery. The one photo shows the vent and the other shows the gas tube(where the gas goes in) to show where its located better. What are the purpose of these? I wouldn't have found them if the flaps on the vents wouldnt of made noise and made me look in there.
Old Nov 10, 2005 | 03:24 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Trunk vents?
ORIGINAL: baddog671
They allow drainage of the trunk in case of a flood and also allow presure equalization in the passenger compartment. Passenger compartments are typically water tight against rain but not airtight. Otherwise you would run the risk of blowing out your windows everytime you closed your door. With the trunk, same thing. You would mess up the seal on the trunk if it all the air compressed when you closed the lid everytime. The air has to go somewhere.
Old Nov 10, 2005 | 07:56 PM
baddog671's Avatar
baddog671
Ok, I guess that makes since. But you would have so much water in your trunk before it would go out the vents.
Old Nov 10, 2005 | 07:58 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Well I haven't seen the exact location of them... if they are as high up as you say then it's for air dispersion. Some cars have them hidden better than others. My old nissan sentra had them exposed in the trunk with a flimsy flap to keep water from getting in [&:]
Old Nov 10, 2005 | 08:12 PM
baddog671's Avatar
baddog671
Ok, yea, it would definitly seep into the cabin area before it went through those vents, maybe 2 or 3 inches above the "trunk floor" and the tire area would fill first..
Old Nov 10, 2005 | 08:17 PM
PipsBlackStang's Avatar
PipsBlackStang
Old Nov 10, 2005 | 09:08 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
ORIGINAL: Derf00
you have an overactive imagination. no way could you close the door and build up enough pressure to blow out your window. air is easy to compress. I'm sure the vents are there to equalize pressure. Probably so your ears don't pop everytime you get out of the car.
Old Nov 11, 2005 | 01:51 AM
baddog671's Avatar
baddog671
Even if you didnt have those vetns and you shut the trunk, wouldnt the air go to the cabin through the seat area and more overly up through the extra openings on the reardeck lid? I think I have to agree with redass here, I dont a window would...blow out.
mrtrodonet
Sep 19, 2020 03:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Beerman309
Sep 19, 2015 01:16 AM
movielover40
Sep 15, 2015 10:37 AM
tmdm
Sep 4, 2015 06:45 PM
