Stupid question
Ok...I have an 01 Cobra and I can't find the PCV valve or vacuum hose to use for Seafoam...I know its a stuid question but can someone please just tell me where it is??
This is so frustrating lol
ORIGINAL: sprostang
PCV valve. Drivers side valve cover, top/middle below the EGR valve.
I have an 02 GT and the driver side PCV valve goes into my instake. The pasenger side PCV goes into the upper intake which I believe is the correct place-Shane
ORIGINAL: shane361
ORIGINAL: sprostang
First of all..GARY..the guy came in here to ask questions about it. If you know something that he doesnt then "explain" to him and many others why YOU feel that stuff is a bad idea. Ever heard of constructive critisism...or just like being an ***?
2nd of all..here is a little more info but I have seen much more on the subject-Shane
http://www.corral.net/forums/showthread.php?t=70683
I have a friend, Ford tech. He saying he has seen engines, new 4.6L, with heads stripped, cams worn, at around 50k miles. What should happen at 800k he saw at 50k when people used that ****. Also, FOMOCO will void your warrany if you use that product. That's all.
Gary
Gary
There is nothing wrong with using SEAFOAM in your car. That is BS that you would post that it will damage your engine. Show us the proof that it does damage and show me a link that says ford will void your warrenty. Hell if we listened to the techs. at all these dealerships there wouldnt be any aftermarket parts because according to them everything will void your warrenties.
