Bad EGR?
Old Nov 16, 2005 | 11:45 PM
ellis_juan's Avatar
ellis_juan
Default Bad EGR?
What are the signs of a bad EGR valve?
Old Nov 18, 2005 | 08:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Bad EGR?
Fluxuating idle and mis-fire at steady speed w/slight throttle pressure. There are a few things you could do to test it. 1) unplug the vacuum line and put a golf T in it to plug it, then drive the car to see if the problem stops. 2) test the EGR vavle w/a vacuum pump and gauge to see if it'd hold vacuum. 3) unplug vacuum line, reach under valve and manually depress(you'd press upward, toward the sky) the diaphram then place your finger over the vacuum port on the valve and let go of the diaphram. If it doesn't hold vacuum it's got a vacuum leak. 4) buy a new EGR and see what happens. If it's the original EGR valve, then i'm willing to bet that's the cause.
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
GLOCKer
Sep 28, 2015 07:36 AM
