Traction Control
Old Nov 19, 2005 | 10:23 PM
MCFAST's Avatar
MCFAST
Default Traction Control
How does the Traction Control, work on the 99 SVT and is it any good?
Old Nov 19, 2005 | 10:54 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Traction Control
When the tires start to spin, it cuts fuel to the engine to keep engine from revving higher to help to keep car straight from spinning the tires. I have it and hate it. It sucks in other words, especially when you hit 2nd gear hard and it activates when your tires chirp. When I get my tuner, it will be turned off for good. Then I can do this without a problem[sm=gears.gif]
Old Nov 19, 2005 | 11:08 PM
MustangChris04's Avatar
MustangChris04
cant u just hit a button to turn it off?
Old Nov 19, 2005 | 11:20 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: XbcSharpShooter
Yeah, but you need to do that every time you start the car. Not a big deal, but sometimes you would forget. But im getting a tuner when I get my gears and one of the options in the tuner is to shut off the traction control.
Old Nov 20, 2005 | 03:32 AM
ShadowDrake's Avatar
ShadowDrake
Here's what it does:
First applies the rear brakes enough to stop wheelspin, if the spin continues, or is very bad, it then retards the timing, which reduces the torque of the engine for approx. three seconds, if the wheels do not spin in that time, the timing returns to normal and the little light in the instrument cluster turns off.
Old Nov 21, 2005 | 11:26 AM
nanaki's Avatar
nanaki
Retired MF Moderator
when it breaks, it starts applying the breaks per wheel. that thing almost caused me to get in an accident rather than prevent it. i HATE TC. mine is perm disabled.
Old Nov 21, 2005 | 11:29 AM
sandcracker21's Avatar
sandcracker21
ORIGINAL: nanaki
^^^ its true, i almost died bc of it too!
Old Nov 21, 2005 | 03:46 PM
Birdieman4's Avatar
Birdieman4
What's traction control? I never use it, even in the rain.
Old Nov 21, 2005 | 03:57 PM
angcobra's Avatar
angcobra
I guess I am confused, does it cut fuel or apply rear brakes?
My 03 uses a fuel cut, that I have disabled with Predator.
Old Nov 21, 2005 | 05:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
http://www.edmunds.com/ownership/saf...2/article.html
depends on the year. I believe the 04 and older will cut fuel if tire spin is severe enough.
