convertible top
Old Nov 22, 2005 | 01:04 PM
mcguffey4's Avatar
mcguffey4
Default convertible top
i have a 90 5.0 mustang when i hit the top button it just clicks any ideas.
Old Nov 22, 2005 | 02:35 PM
Pyrat's Avatar
Pyrat
Default RE: convertible top
ORIGINAL: mcguffey4
Where is the clicking sound coming from, the switch or ??? If it is the switch, pull the switch and verify all wires have a good mechanical connection. If so, use a multimeter to verify the input and output. If it is a motor, again, make sure all wires have a good mechanical connection and use your multimeter to verify the input/output.
Old Nov 22, 2005 | 04:47 PM
mcguffey4's Avatar
mcguffey4
the clicking is coming from somwhere around the pump.
Old Nov 23, 2005 | 12:03 AM
nitrous_bob's Avatar
nitrous_bob
i'd say the hydraulic pump is shot.
Old Nov 23, 2005 | 01:43 AM
Pyrat's Avatar
Pyrat
It might be the motor that drives the pump. I tried to look up the cost of the whole unit and came up with a price of $530 for a new one. You still want to verify you are getting power to the motor. If you are, take a look at the unit and see if you can separate the motor from the pump. You might be able to get a part number off the motor and just buy it. If not, it's probably time to hit the salvage yards.
Interestingly I found this on a site called http://www.all-parts.com/diagnostics...nvertible.html
1990 Ford Mustang Convertible
All Part Groups Other Not applicable Not applicable
Q: I have a convertible... When you hit the switch to open or shut the top, it just clicks - no action. Where should I look??
A: Power to the switch??.... Then power from the switch??.... Then power into the motor??? If yes to all three, buy a new motor
chrisdbassplayer
Oct 13, 2015 06:53 PM
folivier
Oct 2, 2015 05:34 AM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
folivier
Sep 26, 2015 02:28 PM
