Shifter stuck in Park
Old Nov 24, 2005 | 12:18 PM
unclebilly's Avatar
unclebilly
Default Shifter stuck in Park
After doing a comprehensive search of this site, I've decided to go ahead and post a question... a friend's 94 3.8L mustang with an automatic has recently started getting stuck in park after it has been parked. What might be the problem? Where do we start to diagnose this one?
THe button on the shifter is impossible (or at least very difficult) to press.
Old Nov 24, 2005 | 12:20 PM
wildazme's Avatar
wildazme
Default RE: Shifter stuck in Park
Im having the same problem with my 98 auto. It gets worse when its cold out. i have to let the car idle for a few minutes and warm up before i can get it out of gear. you could press the button until your finger is ready to break off and it wont come out of gear.
Old Nov 24, 2005 | 01:16 PM
bryanec's Avatar
bryanec
It is prob. the brake switch. You cant push the button in unless the brake is on.
Old Nov 24, 2005 | 01:30 PM
nitrous_bob's Avatar
nitrous_bob
for some reason that i do not know , and unable to explain, it could be a switch in the column as well. i oly say this because i had a '95 lt1 and it did that, the key was also not coming out, i thought the cylinder was bad, the locksmith came out and replaced a module of some sort in the column, it was burned out.
Old Nov 24, 2005 | 04:51 PM
wildazme's Avatar
wildazme
where would the brake switch be located on a 98 gt?
Old Nov 24, 2005 | 05:34 PM
waxyourboard's Avatar
waxyourboard
Does it happen when you park on a hill? try pulling the parking brake before you shift into park when you're parking
Old Nov 25, 2005 | 11:53 PM
wildazme's Avatar
wildazme
happens all the time when the car is cold.
Old Nov 26, 2005 | 12:05 AM
Acer2428's Avatar
Acer2428
Site Mod
ORIGINAL: waxyourboard
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
