switching from 85 to 140 speed
Old Jan 17, 2004 | 04:12 AM
jt351's Avatar
jt351
Default switching from 85 to 140 speed
All after market tach's aka moster tach either have2 loops of wires hanging out instructions tell you by default it is set for 8cyl, cut 1 of them for 6 cyl, and both for 4cyl. My monster Tach is set electronically, To cahnge it to to either 4,6,8, or 10 I have to hold a button on it while turning the key on and then hit the button til the tach reads the number of cyl I have, just do a search on the internet for instructions, I had a cheaper tach from autozone it had a switch on the front for 4, 6, or 8 </P>
Old Jan 17, 2004 | 04:30 AM
jt351's Avatar
jt351
Trust me all, You need the speedo head only, After you take the cover off the cluster it seperates into 4 sections, volt&amp;temp, tach, speedo,fuel&amp;oil just change the speedo section, I have done this myself, and I am a ASE certifed mechanic,been working on fords for 18years,and I have owed over 25 79 and newer mustangs, i have made just about every combination and know what works, also about the speedo, it will be accurate, if it is off, it was off before or you got a bad speedo, because if you put wrong size tires or differnt gears you are not off by 3to5 miles you would be off by a % therfore faster you go the more you are off. But a speedo is a speedo.
Old Jan 17, 2004 | 10:24 AM
kylx's Avatar
kylx
it is easy to do
Old Jan 17, 2004 | 01:28 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
</P>
k, so just the speedo will work? cause thats all i really wanted, i just though u couldnt switch without switching the whole thing</P>
Old Jan 17, 2004 | 10:53 PM
vfast's Avatar
vfast
I ♥ Acer
jug..don't p**** out on the 4 banger with the turbo..we talked about it we have 1 running mid 12's..but you need to find an intercooler. same guys doing the v-8 swap will be cry'in thier *** off when a 4 banger waxes their ****L* so will the lil ricer too<edited><editID>vfast</editID><editDate>38003.8706944444</editDate></edited>
Old Jan 18, 2004 | 03:08 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
</P>
im already intercooled<IMG src=smileys/smiley2.gif border="0"></P>
how do i know what injectors i have? i think theyre black...<IMG src=smileys/smiley24.gif border="0"></P>
fyi turns out i probly have a stock head and intake so thats something i can swap for some decent power also...and cam...and i need a header...know where i can get one? im not sure how big the turbine wheel is (i think they can be 48mm or 60mm right?) and i think that effects what size flange on the header ill need so i gotta find that out also.</P>
Old Jan 18, 2004 | 03:25 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
You wont be waxing my ***!</P>
</P>
Old Jan 18, 2004 | 03:29 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
but i could surprise fairly bolt-on bearing 5.0's which is all i need...guy at school has a 90 gt with like 175k miles, but i hear a tale hes getting some crate engine. i wanna run him before i dont have a chance! lol
Old Jan 18, 2004 | 03:33 AM
vfast's Avatar
vfast
I ♥ Acer
my lil red 'stang will wax ya ***
Old Jan 18, 2004 | 03:57 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
we'll see...<IMG src=smileys/smiley16.gif border="0"></P>
err...you meant him...watch out or ill get both of ya lol</P><edited><editID>Jugador</editID><editDate>38004.0861574074</editDate></edited>
